Strava acaba com BLE e ANT+
URL: https://www.pedal.com.br/forum/forum_posts.asp?TID=97343
Data da Impressão: 19 Abr 2024 as 13:41 Versão do Software: Web Wiz Forums 12.07 - https://www.webwizforums.com
Tópico: Strava acaba com BLE e ANT+
Postado Por: Leo Amaral
Assunto: Strava acaba com BLE e ANT+
Data de Publicação: 17 Out 2019 as 06:11
Hi Leo,
When you record a workout on Strava, it’s our job to make sure your effort is captured accurately and reliably. We recently discovered that pairing Bluetooth heart rate monitors and power meters directly with the app is causing Strava to crash for millions of athletes — most of whom don’t even use these kinds of sensors. So to significantly improve the stability of the app, we’ll no longer support direct Bluetooth and ANT+ device pairing as of October 28th, 2019.
If you record activities using a GPS watch or bike computer, this change will not affect you at all. But if you want to record activities using your phone and capture sensor data, you’ll have to record with one of the many apps that upload to Strava. Here are some tips to get you started. We know that even small changes in your routine or equipment can make a big difference, so we appreciate your understanding.
Here’s to your efforts making it into the books. Every time.
The Strava Team
Data de Publicação: 17 Out 2019 as 06:44
I am with my Cateye Strada wireless cyclocomputer and "I don't open", hehehehe...
Postado Por: wi85sc
Data de Publicação: 17 Out 2019 as 07:02
Let's use Endomondo app! Strava also stopped API for relive app. Cya
Data de Publicação: 17 Out 2019 as 07:40
Tá de sacanagem?
Adeus strava!
R.I.P
Data de Publicação: 17 Out 2019 as 07:51
Os sensores estavam afetando a estabilidade do serviço, como viram que pouquíssimos usuários utilizavam os sensores ligados diretamente no aplicativo/smartphone, resolveram tirar a função...
Mas não afeta em nada os dados de quem usa GPS e sobe para o Strava...
Hoje com uns 300 reais você consegue importar um Bryton ou Igpsport pelo Aliexpress... Bom investimento para quem quer treinar...
Data de Publicação: 17 Out 2019 as 10:28
Ums questão: como fica o summit?
Postado Por: lemarco
Data de Publicação: 18 Out 2019 as 08:54
Bug, sei... http://www.palabraderunner.com/garmin-compra-strava-por-103-millones/" rel="nofollow - http://www.palabraderunner.com/garmin-compra-strava-por-103-millones/
Data de Publicação: 18 Out 2019 as 09:11
lemarco escreveu:
Bug, sei... http://www.palabraderunner.com/garmin-compra-strava-por-103-millones/" rel="nofollow - http://www.palabraderunner.com/garmin-compra-strava-por-103-millones/ |
Data de Publicação: 18 Out 2019 as 09:30
Não é verídico... E a notícia é de 2016.
Postado Por: CaioB
Data de Publicação: 18 Out 2019 as 09:51
Não é de todo ruim, o Strava é um bom app, mas assim como o celular que é feito para fazer dezenas de coisas, o GPS não é preciso, altimetria não é precisa, distância e velocidade não são precisos, para isso existe os GPS nativos, que foi-se o tempo que eram caros, um IGSPORT ou um Bryton acha-se bem em conta, e convenhamos, se é para ter um sensor de cadência e cinta, melhor que seja registrado em um equipamento próprio.
Data de Publicação: 18 Out 2019 as 09:54
Para quem usa GPS (ciclos ou de pulso) e Smartwatch's não muda nada...
As informações vindas de aplicativos e aparelhos terceiros vão continuar subindo normal para o Strava, ele só não fara mais a a leitura destes dados diretamente pelo aplicativo...
Leo Amaral escreveu:
Ums questão: como fica o summit? |
Data de Publicação: 18 Out 2019 as 09:55
Fala como se um Bryton ou Igsport tivessem GPS melhor que um celular...
Data de Publicação: 18 Out 2019 as 09:59
Teoricamente sim...
Qualquer aparelho otimizado para fazer apenas aquilo sera sairá melhor que um aparelho feito para diversas funções, mesmo que use hardware inferior...
A leitura do GPS pelo Smartphone é afetado pelas diversas funções do celular, que nem sempre é controlado pelo usuário, acesso a localização por diversos aplicativos, atrasos de processamento, etc...
Os arquivos gravados pelo strava são normalmente menores que os desses GPS (ciclos), o que demostra que menos pontos são gravados, havendo mais interpolação, diminuindo a precisão...
Nos ciclos normalmente você pode escolher duas ou mais formas de gravação dos pontos, diminuindo ou aumentando a interpolação, consecutivamente deixando mais ou menos preciso, porem para aumentar a precisão ira gastar mais bateria...
ghd escreveu:
Fala como se um Bryton ou Igsport tivessem GPS melhor que um celular... |
Postado Por: CaioB
Data de Publicação: 18 Out 2019 as 10:04
ghd escreveu:
Um Igsport vai dar diferença para um Bryton, assim como o Bryton vai dar diferença pro Garmin, e o Garmin vai dar diferença pro Polar...
Cada um marca de um jeito, nunca nenhuma marca os dados serão iguais, agora, qualquer GPS que seja dedicado somente a GPS, obviamente serão melhores que um celular.
Até porque, os celulares além de ter o GPS, tem que se "preocupar" com câmera, torre, aplicativos, sistema operacional, mensagens,etc, etc, etc, é a velha máxima que faz de tudo, mas nem tudo faz melhor. Um celular tira fotos, mas não é melhor que uma câmera profissional.
Data de Publicação: 18 Out 2019 as 10:23
Em questão de altimetria podem dar grandes diferenças como comentei em outro tópico...
Agora em termos de distancia, as diferenças são bem pequenas, nesse ponto os GPS são confiáveis, desde que recebam sinal, rs...
Altimetria sempre sera estimada, seja de Marca X, Y ou Z... Nenhum deles tem um altímetro de precisão... Pessoal tem a usar o Garmin como referencia absoluta, reconheço que o marketing dos cara é bom... rs..
CaioB escreveu:
ghd escreveu:
Postado Por: CaioB
Data de Publicação: 18 Out 2019 as 10:34
rafael_rtg escreveu:
Altimetria sempre sera estimada, seja de Marca X, Y ou Z... Nenhum deles tem um altímetro de precisão... Pessoal tem a usar o Garmin como referencia absoluta, reconheço que o marketing dos cara é bom... rs.. |
Distância como são baseados em mapa, da pouca diferença, já altimetria o Strava faz baseando com os dados que ele tem de acordo com o relevo, os Garmins em sua maioria tem barômetro, ai entra o X da questão, ele também não vai ser 100% preciso como um barômetro nativo, mas ja é melhor que o Strava.
Sendo um GPS voltado somente para esporte, vai ser bem superior a um aplicativo de celular, seja qual for.
Data de Publicação: 18 Out 2019 as 10:42
So uma correção, GPS em si não possuem mapas, ele não sabe sabe em que rua você esta, ele sabe quais pontos cardiais você esta, rs...
Ele vai gravando esses pontos de tempo em tempo (as vezes a cada milésimos, ou as vezes a cada poucos segundos)... A interligação entre esse pontos é que vai dizer a distancia... O tempo entre um ponto e outro dará a velocidade...
Depois de salvos, aplicativos (softwares), podem fazer correções desses pontos através de um mapa, ele vai corrigir por exemplo se um ponto sai muito fora de um traçado ja mapeado... Ai sim podem surgir diferenças das formas de correção de uma marca para outra...
Pessoal fica intrigado quando digo que um sensor de velocidade daqueles de imas, instalado na roda traseira e configurado com exatidão a circunferência do pneu, é mais preciso que um GPS, rs...
CaioB escreveu:
Distância como são baseados em mapa, da pouca diferença...
Postado Por: ajunio3
Data de Publicação: 18 Out 2019 as 11:00
Até onde sei, celular não tem altímetro barométrico, logo, gravando no strava do celular vc nunca terá um dado de altimetria real, mas sim o que os mapas cartográficos usados pelo site do strava usam pra, sobrepondo as coordenadas por onde vc passou, conhecendo o mapa do relevo, calcular a altimetria teórica. Logo, se vc sobe uma passarela, que não ta no mapa, vc não ganha esta altimeria
Brytons, Garmins, etc possuem altímetros barométricos, que apesar de também não serem um primor de precisão, estão sim medindo as diferenças de altude real, logo, medindo o ganho altimétrico real. Sobe uma passarela, ele mede o ganho.
Um exemplo do primeiro caso é, fizeram uma rodovia nova aqui perto de casa (quem é da região, chama-se via metropolitana perto de Lauro de Freitas) e escavaram e demoliram, vários morros pra abrir a estrada
So que, o Strava não atualizou os mapas cartográficos, e pra ele os morros ainda estão lá
Resultado: Grava no celular, dá 2.000m de altimeria hahahaha (galera que comemora aqui virou piada) Grava no Garmin, dá nem 250m
Data de Publicação: 18 Out 2019 as 12:09
Teoricamente sim...
ghd escreveu:
Você se esquece que a indústria do celular é bizarramente mais competitiva e melhor desenvolvida do que a de "GPS para ciclismo".
Poder de processamento em um celular é muito maior. Fora as assistências ao GPS que são possíveis em um smartphone.
Até mesmo projeto e confecção de antena podem ser melhores. Além do maior espaço para ela.
Edit: Para não ficar só no blablabla https://support.garmin.com/en-US/?faq=aZc8RezeAb9LjCDpJplTY7 Garmin confirma precisão dentro de 15m
Estudo mostra que um IPhone 6 (antigo já hein) tem precisão de 7 a 13m. https://journals.plos.org/plosone/article?id=10.1371/journal.pone.0219890
Postado Por: CaioB
Data de Publicação: 18 Out 2019 as 12:31
Não precisa-se de competição para GPS, precisa-se de qualidade e confiabilidade, coisa que algo NATIVO para isso faz.
Como disse, as fotos de uma iPhone são boas, ótimas, até da para descartar uma câmera DSLR, mas aproxima a foto para você ver.
Data de Publicação: 18 Out 2019 as 12:33
CaioB escreveu:
Como disse, as fotos de uma iPhone são boas, ótimas, até da para descartar uma câmera DSLR, mas aproxima a foto para você ver. |
E vc diz isso com base em que?
Pelo menos leu o que postei acima?
Data de Publicação: 18 Out 2019 as 12:42
celulares DE HOJE não devem nada para aparelhos exclusivos GPS. E em percurso urbano, acredito que o strava se saia até melhor que um GPS, pois ele reconhece as vias e usa elas para calcular a distância, corrigindo o zig-zag dos pontos devido a imprecisão do GPS.
Em distância, não há um ganho absurdo usar smartphone com app ou gps dedicado. Na altimetria sim, desde que o GPS tenha um bom altímetro, pois este sofre variações devido ao clima.
Postado Por: cdamaso
Data de Publicação: 18 Out 2019 as 13:34
ghd escreveu:
| Complementando, Broadcom prometeu precisão de 30cm em 2017, links abaixo, conhecendo competência deles eu acredito que tenham conseguido, e a Qualcomm deve estar na mesma pegada. Um review do Xperia Z3 Compact(2015) já citava precisão de 10m, inclusive, tive um, usei bastante o GPS dele e a promessa era condizente ao que entregava.
https://olhardigital.com.br/noticia/precisao-do-gps-sera-de-ate-30-centimetros-em-smartphones-do-ano-que-vem/71278" rel="nofollow - https://olhardigital.com.br/noticia/precisao-do-gps-sera-de-ate-30-centimetros-em-smartphones-do-ano-que-vem/71278
https://www.tecmundo.com.br/produto/122404-novo-sistema-gps-smartphones-ter-precisao-30-cm.htm" rel="nofollow - https://www.tecmundo.com.br/produto/122404-novo-sistema-gps-smartphones-ter-precisao-30-cm.htm
Acredito que da mesma maneira que os smartphones engoliram as cameras/filmadoras de entrada, o mesmo vai ocorrer com outros equipamentos, isso inclui os GPS de entrada, criando um buraco entre os modelos muito baratos e os caríssimos topo de linha.
Data de Publicação: 18 Out 2019 as 15:13
Tudo que eu quero quando vou pedalar é descomplicar. Ligo meu Gps, os sensores já estão conectados, a atividade inicia automaticamente e pedalo...
Galera do celular aqui vive dando pau, celular entra em modo de economia de bateria e desliga o gps, perde um trecho enorme e ainda diz que o Strava roubou!
Gps é o que há, configuro para ver as informações que quero e preciso e ando com um equipamento leve e de 2 ou 3 polegadas afixado em suporte adequado e projetado para tal... Aí vem a galera com aquela mochilas penduradas no guidão...
Quanto ao Strava não aceitar sensores, não tenho opinião formada. Com bons GPS a preços módicos, não vejo necessidade de surrar a bateria do celular pra marcar atividade física. Estou usando um IGS618 que custa uns 20% do valor de um celular top de linha e que me atende e ainda consio pedalar 15/16h sem recarregar a bateria... depois passo de uma vez pro Strava e analiso os dados que quero!
Não consigo ver vantagem em utilizar o celular para tal, apenas desvantagens (peso, risco de queda do celular, bateria aquecendo nos bolsos, gps falhando ou desligando, necessidade de abrir app toda hora, impossibilidade de verificar dados em tempo real - a não ser que coloque o tijolar no guidão - ausência de sensor barométrico...)
Quanto a precisão, o etrex da Garmin para uso profissional tem precisão menor que 5 metros em 95% do tempo... Creio que a linha 30 da garmin tenha a mesma precisão. Em fóruns estrangeiros se fala até em 3 metros de precisão.
Postado Por: rod_br
Data de Publicação: 18 Out 2019 as 15:44
Gostei bastante do Polar Flow. É até possível sincronizar os dados do GPS Polar com o Strava, mas vou abrir mão pois o Polar Flow me dá mais informações.
Data de Publicação: 18 Out 2019 as 18:11
dimas2dimas escreveu:
Tudo que eu quero quando vou pedalar é descomplicar... | Exato, abro meu Strava, clico iniciar, coloco no bolso e vou embora. Eu sou o usuário que não dá tanta importância a informação em tempo real, basta ter os registros que fico satisfeito.
Deixar o smartphone entrar em modo de economia de bateria é coisa de gente descuidada, mesmo que não vá usar ele com algum APP de monitoramento ele pode ser necessário em alguma emergência, e esse é um descuido ainda maior atualmente com os aparelhos novos ganhando mais autonomia, atualmente uso um Moto Z2 Play que já vai fazer 2 anos e a bateria ainda dura o dia inteiro fácil, muito diferente da época que tive um iPhone 5 que precisava ser carregado 3 vezes ao dia. Os problemas com Strava EU nunca tive.
Ainda acho que, se já não apareceu, logo vai aparecer um "concentrador" pra conectar todos os sensores e ele ao celular, agregando mais um recurso aos smartphones e reduzindo a necessidade de outros aparelhos. É provável que apareçam até smartphones para um nicho esportivo, se acham improvável, lembrem-se que até a Caterpillar tem suas próprias linhas de smartphones que vão desde a gama de uso "comum" até os que aguentam exposição a ambiente agressivo. Além disso, como citei acima, Broadcom já está prometendo 30cm de precisão, se a Garmin promete 5 metros então já está começando a ficar pra trás, e não imagino o porque já que a Garmin deve usar componentes da Qualcomm ou da Broadcom mesmo que desatualizados.
Posso estar enganado, e nesse caso eu não ligo se estiver, mas os GPS de entrada vão seguir os mesmos passos das cameras/filmadoras de entrada, pager, iPod....
Postado Por: azazel66
Data de Publicação: 18 Out 2019 as 19:11
Vou comentar só sobre a bateria do celular, calibrem o desempenho máximo e máxima precisa, e coloca no modo avião logo após iniciar a atividade, pronto, gps mascando pequenos pontos e bateria de mais de 15 hrs (em modo avião, outros apps não ligam e não competem com o gps pelo desempenho).
Meu celular e o garmin do pessoal tem pequenas diferenças, mas os garmins entre si tbm tem pequenas diferenças...
Data de Publicação: 18 Out 2019 as 19:28
Compreendo. Para algunsm um celular atende ao básico, mas para usuários mais avançados, saber em tempo real dados de frequência cardíaca, cadência, ter um contador de voltas/cronometro para tiros e descansos e até mesmo potência faz toda diferença. Creio que o avanço se dará com as tecnologias descendo aos modelos de entrada, agregando funcionalidades e se tornando cada vez mais específicos para a atividade. Continuo não vendo praticidade em carregar 200 e 6 polegadas no bolso somente pra marcar o percurso ao final do pedal. Teria facilmente um Garmin 1030 com a parafernália toda se o preço não fosse tão proibitivo.
Questionar a utilidade de um GPS dedicado apenas por sua "precisão", descartando todo o pacote agregado no aparelho é desmerecer uma ferramenta amplamente difundida e comprovadamente eficaz (os caras do Pro-Tour tem cada um o seu...). Agora é impossível ficar rodando com o celular afixado ao guidão para ter informações em tempo real. Sou adepto do GPS, acho fantástico e acho o celular um trambolho (levo um pequeno só pra ligar em caso de emergência, quando vou em grupo nem levo).
Por fim, cada equipamento atende a um publico, e faço definitivamente parte dos que necessitam saber o que ocorre em tempo real, não apenas o quanto e por onde andei.
Grande abraço! Vamos de celular ou Gps, mas vamos pedalando!
Data de Publicação: 19 Out 2019 as 08:54
Grande abraço! Vamos de celular ou Gps, mas vamos pedalando! |
Eu entendo que o cara que TREINA, precisa ter os dados em tempo real para regular seu treino, e para isso o celular não é uma boa opção.
Para o cara que PEDALA, o celular com app cumpre muito bem seu papel.
O argumento do aparelho dedicado ser melhor que smartphone não cola, pq hoje em dia tem cada smartphone com hardware bem melhor que aparelhos dedicados. Por um único motivo: Quantos garmin são fabricados e quantos iphones são fabricados?
Smartphones são produzidos em quantidades gigantescas, viabilizando acesso de micro-componentes de alta precisão, caso visto nas câmeras por exemplo e na sequência GPS, acelerômetros e outros sensores.
Postado Por: Jagwire
Data de Publicação: 19 Out 2019 as 13:05
A grande falha que vejo nos GPS próprios pra ciclismo, é ele não ter a função básica de celular: colocar um chip e fazer ligações. Se encontrasse um aparelho (seja gps de guidão ou de pulso / relógio) que permitisse fazer uma ligação em caso de necessidade, seria a minha escolha (desde que não custasse uma fortuna).
Data de Publicação: 21 Out 2019 as 08:41
Jagwire escreveu:
Permitir fazer ligação, implicaria em colocar uma antena, sendo esta a maior consumidora de bateria num smartphone hoje. Aí perderia a vantagem do aparelho dedicado, se transformando num aparelho grande (para receber uma bateria maior) e perderia autonomia, problema dos celulares de hoje.
Pra quem usa GPS, compra um celular destes que vendem como sendo para idoso, que ainda possuem teclado gigantesco e a bateria dura 235 dias. Vendem por volta de 100 reais, perfeito pra carregar junto no pedal para ligações de emergência.
Data de Publicação: 21 Out 2019 as 08:43
Todavia, com essa retirada do BLE no strava, baixei o endomondo... Mas é foda, os segmentos do straga fazem toda a diferença no APP...
Data de Publicação: 21 Out 2019 as 19:38
gm1987 escreveu:
Pra quem usa GPS, compra um celular destes que vendem como sendo para idoso, que ainda possuem teclado gigantesco e a bateria dura 235 dias. Vendem por volta de 100 reais, perfeito pra carregar junto no pedal para ligações de emergência. [/QUOTE]
Pois é, já fiz isso no passado (com um celular velho que tinha ainda funcionava), a desgraça era ficar tirando o sim card do smartphone pra por no celular, reconfigurar os aparelhos, e pior quando firou chip nano. Um gps poderia ter um eSim, e alguma espécie de modo avião, onde o chip só fosse ativado quando precisasse, numa eventualidade. Pesquisando, achei o xiaomi Verge 2 que faz isso, mas ainda é lançamento, aguardando melhores avaliações.
Data de Publicação: 24 Out 2019 as 17:01
Bom, seguindo a recomendação do STRAGA, baixei o wahoo e fui pro ride...
1 - Quando tu carrega a atividade no strava, ela vem como corrida, pois o app do wahoo não tem opção para ciclismo. Facilmente corrigindo editando a atividade no straGa, mas é mais uma coisa a fazer...
2- Sincronizei as contas, subiu a atividade, mas não marcou nenhuma colocação nos segmentos. Será que estas atividades não irão gravar KOM nem posição no ranking dos segmentos?
Se for realmente assim, straGaram o lance... Tentei usar o endomondo e sports tracker, mas ambos não sincronizaram com a cinta, somente o wahoo
